Online: beaglebasher
2007 Street Bob - Winter Cosmetic Changes
    Looking at more changes... turning more chrome into black.
    All this plus the fender struts are going in for powdercoating. Standard HD is gloss-black, but I was thinking either matt-black or the HD-wrinkle-black
  • Ando
    Ando
    WILL LOOK A TREAT AND A GOOD CHANGE UP TO FRESHEN UP THE LOOK
    This is the current look
    after I removed the rear fender I got to thinking.... should I also cut the fender and install new tail light
    JFE commented in a seperate post "Yep, black is the way to go! Which colour do you think you will go with? Depends on 'the vision' I suppose. I've found that a bit of gloss black and Matt black across the bike works nicely."
    I saw these strut covers online and liked the look. Thinking wrinkle finish might be too abrasive and overcook the look
    not a clear photo, but like this matt finish
    Just not sure about wrinkle finish
    great so far
  • JFE
    JFE
    For my additional 2c, I'm not 100% on the wrinkle black strut either. Gloss for the win (I love my gloss black struts).
    Perhaps a different way of looking it is to swap out the belt guard for a gloss black one therefore easing the amount of 'wrinkle' on the eye? I have a black RSD one that is a bit like a Sportster guard and it looks primo IMO.
    Now cleaned up the headlight... although still need to paint the headlight mounting post (and wash the bike.. lol)
    High Beam
    Low Beam
  • DarKasH69
    DarKasH69
    Looks great mate.
  • JFE
    JFE
    The new light changes the look completely (for the better). Looks more modern and menacing. I like where you are going with this Uncle Ho!
    Looks good uncle Ho. Looking forward to seeing your before and (finished) after pics.
    Bike looked pretty good at the start too. Same silver superglide as a mate of mines
  • John.R
    John.R
    Did you have to get the chrome stripped off before Powdercoating? Or where they able to just scuff the surface and have it come out alright? Have heard different things from different PC'ers
    the light is certainly an improvment, been asked how it compares to HD's Daymaker... not sure but here are pics of the light in a lit street
    OFF
    LO BEAM
    The pictures don't show a lot of difference, but it is noticeable. You can see the difference in reflective signs and directly behind the car.
