Online:
beaglebasher, Hilly
Fuel Injection Cleaner.
Neale
Anybody use or recommend a particular brand. 08 96 cubic inch FLHT. Thanks in advance.
Daggs
I had Toyota brand recommended to me by one of the few people I listen to about engine advice
Why not just run several tanks of Super Petrol through the bike? They have Injection cleaner built into their mixtures.
Methuselah
Yep, as Tussock says, run BP Ultimate 98 and you'll have no issues.
robnicko
+1 on the BP Ultimate
I also put about 15ml of flashlube upper cyl lube in the tank every 4th or 5th tank. It also helps with keeping injectors clean
Neale
Thanks. I only run 98 BP so I guess I am good.
