Online: beaglebasher
Cv carb slide drill or not
  • chopa
    chopa
    As the topic says should you drill an 1/8" hole in the slide or not. Seem to be so many conflicting views  on this?
    Any advice would be appreciated
    Phil
    Don't .
    If you are serious about tuning, get a Dynojet kit. (not the thunderslide kit)
    would have too do other mods also & jet proper etc
  • Hudson76
    Hudson76
    +1 daddyracer Have mine done with appropriate jetting and engine mods. Mite be over kill on a fairly stock engine though.
  • chopa
    chopa
    thanks for the reply guys. Looks like I'll have to buy a new slide cos mine has been done by previous owner.
    I'm just wondering if that is why my throttle is like a hair trigger cos any small bumps and it gets
    jerky
    Phil
    A simple fix is to fill the hole with some decent epoxy and re-drill .
    Another thing that may have been done is a softer slide spring.
    Also make sure you have the correct play on the throttle cables.
  • chopa
    chopa
    Thanks speedster i will try and get another spring just incase
    Run a small tap through the hole to give the epoxy/JB Weld something to hang onto.
    Current thinking seems to be leaning away from drilling the hole larger.
