Online: beaglebasher, Hilly
Shift Light
  • bodgie1307
    bodgie1307
    HI all couldnt find any recent posts using search ..looking for a programable shift light for my breakout any ideas ??  i think the SE one PN 69779-09 is obsolete
    regards
    Bodgie
  • Lushy
    Lushy
    Google Translogic" they do some good stuff.
  • Mr_Bean
    Mr_Bean
    Raptor performance have some neat lights
    I use the dual shift light.
    https://www.raptorperformance.com/collections/shift-lights
  • bodgie1307
    bodgie1307
    Thanks mr bean been looking at the raptor.. i dont ride in rain so the open board isnt a problem..
    Where did you pick up the feeds from
  • Mr_Bean
    Mr_Bean
    Spliced into the ecm connections
    used a deutsch plug so I don't have to have the light on the bars 24/7 I just tuck it in under the dash
  • bodgie1307
    bodgie1307
    Is that pin 3 on ecm for tach feed ?
    Going to fit same plug to mine to prevent theft
  • Mr_Bean
    Mr_Bean
    I will have a look when I get home today.
    will post the pinout for you
    Pretty sure it is pin 3 & 33 for the vss so the stage light works
