Online: vitalhempbuys
Why doesn't HD put the engine size on their sportsters
  • Biphasic
    Biphasic
    Just wondering if anyone can tell me why HD does not put a badge with the engine size on their sportsters because the 883 & 1200 look so much alike ???
  • fmacdonald
    fmacdonald
    Do you mean on the engine itself or on the bike? My bike as 883 painted on the tank, little do they know it is really a 1250 :)
  • Broke
    Broke
    The VIN says if its a 1200 or 883 - The first field will look like - 5HD = made in USA for sale outside USA. Then either 1 for 1200 or 4 for 883, Then model number, e.g. LE = XL883N, LC = 48 ; CT = 1200Custom. This is from the owners manual
  • brash
    brash
    new ones say 1200 on the timing cover, they got rid of the "5"
     They should have 74 cubic inch or 55 cubic inch as they are American & they don't measure in metric so why do they measure big twin in cubic in h but sportster & V Rod metric can you tell me that?
    Because 55 cubic inches sounds small
    That's HD!! they still have MPH speedo in USA looks slow, but just measuring in KPH does to increase speed. Cubic inch it should be sounds right or are we on metric cruisers?
  • Roo Ted
    Roo Ted
    5 and a half inches sounds small......
  • chriso
    chriso
    Cause no one cares to look at em
  • JMAC168
    JMAC168
    sportsters were initially produced to combat the british imports BSA , Triumphs, Norton etc most of which were 650 cc or 750cc. So on the showroom floor the sporties were in cc so the buyer could compare the engine size to the brit bike without doing a math conversion from CI.
    Hope this helps.
    Cheers John
  • bobby bob
    bobby bob
    haha, so it seems size does matter, or a least the allusion of size.
  • brash
    brash
    yep, that's why HD makes a 110ci engine that puts out 82rwhp haha
    bolt on sporty's make more.
  • 308bever
    308bever
    mine says 883 right on the number plate! lol.
    Brash, yeh the big girl a bit weak, but she can torque! TQ looks ok for stock. but 110C I.
    Look all you need to do is lift a head off, look at the hole!! the 74 c i has a quarter of an inch bigger hole!!
