Online: Humbug, speedzter
Handlebar Risers On A Breakout.
  • Bogie
    Bogie
    Would like to put 1" handlebar risers on my Breakout.  Does anyone know where you can get them... they are also called spacers.
  • Fat Tom
    Fat Tom
    riser spacers, I got a set off ebay cost around $100 you can get 1" to 2" risers. Once on you hardly know they are there and are a cheap alternative to getting another set of bars
  • Bogie
    Bogie
    Thanks for that info.
  • Bogie
    Bogie
    Finally got new bars on the Breakout... what a difference in riding the bike now... cost a lot, but worth it.
  • Sparra
    Sparra
    I just put a set of 1.5" black ones on my Wideglide,got them off ebay..
    Edit..Haahaa,should have checked the date on the original post,bars look good...
    Cheers...
  • Bogie
    Bogie
    Yeah, made a big difference... also got a more comfortable pillion seat... most rides are with a pillion passenger and the little original seat was inadequate.
