Chop z or not to chop z
  • Carrafa79
    Carrafa79
    So I just picked up my 2016 breakout... I asked for the chop z with led lights but they've installed the option for tail tidy and keeping the factory indicators/tail lights.
    I'm undecided if I should keep it as is or get what I paid for:
    Reasons are:
    -I've heard the cops hassle you heaps more and it would be a bitch to get a rwc after it's been modded.
    -the LED lights on the chop z can mess with the ecu
    Has anyone had any issues with these things or have any insight?
    So does the Chop Z come with a statement that its RWC approved? If so then your okay.
  • Carrafa79
    Carrafa79
    Pretty sure it doesn't as your indicators need to 300mm apart to be legal
    I was wondering that... The angles of the plate look okay, so it could just be the indicator distance.
