Online: John.R, Hilly
Danny Gray seat on Rocker c
  • Stevef
    Stevef
    Ok so the install instructions say to stick the clear pad on the rear fender in the "unlikely event" that the seat touches the fender. Well I have raised the ride height as high as it will go and the seat touches the rear fender, is this normal for a Danny Gray weekender on a Rocker C. I have notice that the rear of the seat is quite flexible and that is the reason it comes into contact with the fender. And no I'm not 200 kilos with an arse the size of the moon.
  • RockerStu
    RockerStu
    Yep,happens to me a bit over bumps etc. I'm getting used to pulling myself up on the bars when I do.
  • Stevef
    Stevef
    Thanks RockerStu. Found that the bike is also fitted with aftermarket shocks, lowered and on the softest setting. So raised it a bit and hardend the fucker up. Lot better now, still makes contact but like you only over bumps.
