Online: B0nes
Saggy bags
  • bungalow1
    bungalow1
    Anyone know someone from SEQ who could get these kinks out and reshape my saddlebags. Theyve been sitting in a cupbpard too long. Sorry about the big image. In not tech savvy.
  • FLIPDOG
    FLIPDOG
    maybe wet the bags up/soak them so the leather is soft then tightly fit them with towels till they dry out, then hit em with some leather conditioner, I reckon that would work. No doubt someone will state otherwise if this is not good to do so
  • bungalow1
    bungalow1
    Looks promising. Ill check it out
  • bungalow1
    bungalow1
    Sorta tried it once. Softened the leather up with conditioner and stuffed the towels in but did phuck all. Migt try your method if all else fails.
  • JULES FLS
    JULES FLS
    If the bags are leather, make sure you let them dry naturally. I've had the same problem from tying down my swag over the bags, then getting absolutely drenched and they dried to that shape. Tried several different methods to rectify the problem and nothing brought them back perfectly until I made up a wire frame insert, saturated the bags and pulled into shape. Good luck.
  • FLIPDOG
    FLIPDOG
    how did ya go with the bags mate,maybe others would like to know the result and method used
  • bungalow1
    bungalow1
    Got a quote from Gotsaggybags in the US. Looks like a good product. Just today Cview gave me a contact Hiside leathers. Checked them out but they specialise in riding leathers still I'll give Phil a call.
  • bungalow1
    bungalow1
    Flipdog, bought a Saggybags repair kit from Nevada US. Bit expensive by the time it got here but did the job. They look a treat.
