Online: Stinga
Ebay Parts
    There must be a Chinese factory that has parts left from a Harley Touring run . Plenty on there . Harley Touring search will bring them up .
    What quality are they Timbo?
  • Odin
    Odin
    I have purchased heaps of these Chinese bits for a mate and he reckons ya cant beat them. The quality is good, chroming looks good. Just ordered a taller screen for him for 08 Streety. $38 delivered, cant tell the difference between what he got compared to the one on my new Street Glide
    Picked up side fairing wind deflectors for $38- vs $160- for HD . Fitted perfectly and are very sturdy . Direct from China .
    Gear shift pegs $40-
  • Spencer72
    Spencer72
    What ebay supplier can you recommend.
  • graz
    graz
     Finally ordered the wind deflectors last night from that mob.
  • meddy
    meddy
    Thought I'd give some of these parts from China a try, won a gear shift linkage just over a week ago for the princely sum of $22.82, just finished installing it so thought I'd give a bit of rundown on it.
    The finish on it does show some fine machining marks, so I am thinking maybe they are seconds because it looks exactly the same as the one in the Harley Davidson accessory catalogue.
    Fitting was pretty straightforward althought the acorn nut for the front mount would not fit on the engine side and the bolt would not fit that side either due to being too close to the engine fins so I ended using the thin original bolt on the engine side with some threadlocker on the bolt.
    Time will tell I suppose on it's durability, but for a saving of $160.00 over the dealer price I'm happy to give it a run.
    Looks good for the price
  • G T
    G T
    Ordered some chrome trims for the midframe heat deflectors.
    PS, Tim SG keep an eye on your letterbox as I could not use my PO Box.. cool
  • bad_dog
    bad_dog
    Just fitted the short adjustable highway pegs to my Stree Glide $130 delivered compared to over $500 locally, quality is great only thing that I have noticed different is the bolt that holds them on to the crash bar is not chrome where the original part in the book looks like it is
