Online: B0nes
Brake rotors for FXDF
  • RideHardcore
    RideHardcore
    Is there anyone who knows what are good Brake rotors for my 2011 fxdf? The Stealers said i have a warped front right brake rotor and  want $288.00 each for the standard rotors, that seem way to expensive to me. What are my choices if any?
  • DJP_120ci
    DJP_120ci
    have just put the Harley tear drop rotors on my street Bob, no complaints with them, are was just under 400 for both
    Hope this helps!
    Dylan
  • RideHardcore
    RideHardcore
    Thanks for the info DJP 120ci.
    Did you get them from the (stealer?) as far as I know that was a good price for the teardrops and where can I get them from
    are they in Melbourne? My quote of $288 was for the standard rotors. Is that a fxdf twin disk front end you are running? looks like a nice ride from what I
    can see, must be blast with the 120ci.
  • DJP_120ci
    DJP_120ci
    Yeah that's correct, fat Bob fork sliders with a bit of machine work on the mount for the caliper to line up with the disk.
    I ordered mine through Peter Stevens/Harley heaven in Adelaide. It was the same time I ordered new calipers, sliders/ master cylinder to do the brake upgrade so I may have had a bit knocked off, but I think around 200 per rotor is about the norm.
    Sure is a fun bit of kit to hoon around on that for sure! Have a look through my pics and there is a few more.
    Hope all goes well finding some new rotors.
  • RideHardcore
    RideHardcore
    I rang my HD Dealer today I have decided to go with the Split 7 spoke black, they are still a bit cheaper than the standard rotors and look good.
    Checked out your pics nice ride that you have, are the Ohlins a good ride? I have read a lot about them being good shocks, the price is fairly
    steep. Ya pay good money for quality products if you want them.
    A 120ci in my fat bob is a dream at the moment, one day maybe!
    Thanks again DJP 120ci
  • DJP_120ci
    DJP_120ci
    Glad you sorted it out mate.
    Thanks mate, the ohlins are a good bit of gear, they were on the bike when I bought it so I don't have to much to compare it to.
