Online: Wanderer57
transmission pulley nut
  • STRONG.SURVIVE13
    STRONG.SURVIVE13
    In the process of converting to chain drive. Trans nut is giving me issues. Ive had an electric snap on impact driver on it, breaker bar with metre cheat bar. Nothing. The fuckin thing wont budge. Im thinking pneumatic rattle gun will pop the slut? THOUGHTS PLEASE!!!
  • Ando
    Ando
    cut it off
  • STRONG.SURVIVE13
    STRONG.SURVIVE13
    With what? Dremel?
    Are you doin git in the correct direction....I 'think' those nuts are reverse thread.
  • markwoumla
    markwoumla
    Are you using a locking tool.. Or are you using the brake and gears to lock things down ??
  • STRONG.SURVIVE13
    STRONG.SURVIVE13
    Locking tool. Home made. F clamp locked against swing arm.
    Breaker bar, put some wood against it and wack it with a hammer. Sometimes the shock will loosen it. And mark the nut with a permanent marker, so you can see if it's moving, even slightly.
    lefty tighty , righty loosie
  • Ando
    Ando
    Use a dremel to cut of the nut
    cut it in two halves they are loctited on, need heat to soften the Loctite but this puts the seal at risk, I just cut them straight of now
  • Wildturkey
    Wildturkey
    try an impact gun on it with heat
    You would be the only guy in the world to have a RH Treaded Gearbox, There all Left hand Thread
    +1 to daddy racer and walka clutch hub nut and pulley nut are left hand thread
    +2 You can tell by looking at the exposed thread. Left hand thread looks totally different (lol - I suppose thats obvious)
  • STRONG.SURVIVE13
    STRONG.SURVIVE13
    Im telling use its a RH THREAD. Ill post a picture lf pulley and manual. Anyway got it off with air impact gun, no heat!
  • STRONG.SURVIVE13
    STRONG.SURVIVE13
    Thanks for everyone help. Appreciared. Just to update everyone. 2014 dyna wide glide pulley nut is fucking RH THREAD. Cheers to all????
  • Spook
    Spook
    Good result anyway, old mate. As well, you have advanced the education of some old blokes. (Giggle!)
  • Daggs
    Daggs
    good work bro
    Well done the later bikes must rh thread than as you've pointed out wonder what year thay
    Started doing that .? They are lh thread on older bikes My be that's why they have
    Gone to the trouble of casting in the pulley .
    Had a look see on good old Google and apparently 07 up 6 speeds are rh thread
    Maybe next time put what bike and year you have   Of the thread lolsmiley
  • blueystar
    blueystar
    Ando the man left or right thread he wins 3 cheers
    Hip a ray hip a ray hip a ray
