Online: B0nes
Cams yet again, anbd going over previous.
    Hi mick I only went with se204 cams to keep my warranty. Otherwise I'd have looked at the Andrews 57h and maybe their 48h
    Cycle Rama 570 (or CR 575 ) - big torque, but still carries decent HP
    GMR 577 if you plan on more work later
  • bloodog
    bloodog
    Andrews manufactures the cams for tman, wood, screamin eagle and probably others too.
    Another good midrange cam not mentioned is the tw5-6. All cams mentioned would do a good job and some are so similar you wouldn't notice the difference except some are more costly than others.
  • robots
    robots
    i reckon Comp Cams would make a lot of the stuff in the industry, lifters, cams etc for "others"
    (Andrews owns Comp Cams?)
  • BAKES
    BAKES
    I just installed the SE204 myself last month and they appear to be an under rated cam, and I am very impressed with them, the 585 are also made off the same cam as the 204 with a bit more lift. I guess the real question is what do you want from your cams and how far do you want to go with the cam install, 204 are a simple bolt in job with no other work required.
    As Hilly said, don't over cam it, that can leave you more disappointed.
  • Odin
    Odin
    I have a set of Redshift 527 cams ( bolt in ) here, will probably stick them in my new Street Glide. Hopefully they will make a difference. Not sure about the warranty side of things though
  • Drac
    Drac
    Fred from procycle wanted to try the s&s 570 in my stock 103 and im pretty happy with them.
    Makes 100+ with big shots and air cleaner.
    Dyno sheets are in my pics
