Sump Plug Thread Size?
  • Canbro
    Canbro
    Hey all!
    Last time I did my oil change (engine) I noticed the sump plug seemed to take a looong time to seat. I stopped turning turning the plug after I decided that I had finally stripped the thread - somethiing I am paranoid about every time I change the oil.
    It is now almost due for a change again but I want to have a time sert on hand when I do so the bike is off the road for as little time as possible.
    I can't remember what size the thread is on the sump plug and haven't been able to find it on-line (I never seem to be able to find stuff when I want it - only when I don't need it anymore) and I don't want to pull the plug to measure it as I doubt it will seal again when I put it back in which means I'll be without a ride while I order a time sert.
    So, can anyone tell me what size a sump plug is on an Evo ('94 Dyna)?
    Thanks in advance!
    Should be npt thread what size not sure
  • Canbro
    Canbro
    Thanks Perthhog!
