Online: WideglidingNZ
Lower my 2013 Road King
  • patgreyling@hotmail.com
    hey mates, love my Road K but wish it was an inch lower ! For some reason it is higher than most of the other Harley's. I don't want to spend a gazillion dollars so what is a cheap and effective solution? Would the Profile low touring shocks be worth it?? Appreciate any advice....
    There's a lowering kit for sale in the parts for sale section. Can lower 1-3 inches or similar. Cheap and easy way of doing it
    If you mean those "lowering blocks" whereby you bolt a piece of steel on and can move the angle of the standard shocks backwards to effectively lower the bike ..... I tried those. Very cheap and effective in lowering the bike. Problem is (a) they do have a negative effect on the quality of the ride and (b) they scratch and damage the inside of the panniers. I had them on for a few weeks and .... nope .... not a good solution for the Road King, specially when riding two up with a full load. The suspension effect was lousy.... cheers P
    I have a 1" Lowering Blocks on My Street Glide and very happy with it, I can touch the ground now , The mufflers have scraped going down drive ways some times but it would do that without the Lowering Blocks. I used the LA Choppers version. Cornering your Floor Boards would Scrap way before your Bags Lowered or not
  • Deadwood
    Deadwood
    Road King has 13" shocks, maybe try some Street Glide shocks at 12"
  • moonracker
    moonracker
    when i had my 2012 RK i put i low reach  seat and street glide !2inch shocks on worked a treat
  • Kustomtown
    Kustomtown
    I've got some lowering blocks somewhere if you're after some. Never fitted. PM me if you're interested.
