Online: speedzter
88 to 97 softail changes??
  • rlin87
    rlin87
    Hi!
    Just wondering what changes are made from a 88 softail frame to 97 softail frame? Any help would be appreciated
    Oil filter mounts to remote filter mount on early frames 89 to 93 , I think the turn signal modual mounts to the frame on the later ones Under the speedo/ dash mounts And up to 95 I'm pretty sure there's a mount welded between the upper and
    Lower back bones that the wiring plugs/ plug into to mount apart from those few things. Which arnt a big deal there the same
    Apparently the early 84 are slightly narrower due to chain not belt drive and you can run a early Tc swing arm on the evo
    Frame to run a slightly bigger rear tyre and twin spot rear caliper
  • bobby bob
    bobby bob
    What is the biggest tyre an early soft ail can accommodate?
    160 with std guard before you have to cut the strut horns off plus 1 1/8 belt.
    With the strut horns removed 180 is the norm.
  • rlin87
    rlin87
    Thanks mate! I'm in a pickle I've spent 2 years building a custom softail springer on aftermarket frame but have no MSO, it's based on a 88 softail but can't register now unless stripped back to bare frame and X-ray done one welds, but can get a hold of a legit 97 heritage frame so might get that and just spent the countless hours again stripping it and bolting it all back into the new frame
