Online: softfat, Rouli
Switch Housing Screws
  • Jasbel
    Jasbel
    Hi All
    I need some help please, I stripped one of the Screws from the handlebar switch housing one goes at the top the other goes in the bottom and was wondering where can I get my hands on some replacements, I tried Harley Davidson Davidson with no luck
    Could anyone at least tell me what size they are, It's A 2015 Street Glide if this helps
    Cheers Darren
  • bobby bob
    bobby bob
    try easyR on ebay, you need swithblock hardware.
    Just take one out of the other side and if it's the same length go to a fasteners shop if easy r has them thay will be
    10 times the price and take weeks for you to get them
    measure da depth of da hole & use a full lenght screw even if ya have to cut a longer 1 down to suit do that 1 up 1st then da good 1 last . that will close up da gap 1st & give more thread contact with maybe some 620 loctite , if not just replace da part with original equip , not that aftermarket chrome shit you will be sorry , don't devalue ya bike with tiwain crap that does not work
  • bobby bob
    bobby bob
    stripped the swithblock srews, have to try hard to do that.
    Not really dicast vs steel screw /fine thread thay can strip easily more so over time if thay have
    Been undone a few times
  • Charliewool
    Charliewool
    Trying to do em up too tight to stop them turning?... It's the clutch & brake lever housings that stop the whole lot from twisting on the bars, not the switch housing screws..
