Online: beaglebasher, John.R, speedzter
Do the 2014 and 2015 Softails use the same ECM
  • lockwood
    lockwood
    As in the title, do they use the same ECM? Will the 02 sensor eliminators supposedly work in both year models?
    I have fitted some to my 2015 Fatboy and I am getting the engine check light.
    They are listed as for up to the 2014 model.
    The HD trained mechanic has tried clearing the code but it reappears, even with another ECM
    Any suggestions?
    Thanks
    John
