Exaust removal tools
  • Slatsy
    Slatsy
    hi all quick post I'm interstate got a yellow sticker for noise , I'm getting my original exaust sent up do a quick swap to remove sticker however I have to buy some tools to. Do it , just chasing a list of tools and sizes I'll need to do the job
    Bike is a 2015 softail breakout currently has v&h short shots will be swapping back to factory ,not sure on exaust flange bolt sizes and I think there is a o2 sensor in there aswell
    Cheers SLATSY
  • Nomada
    Nomada
    if ya tell us where you are, someone might offer some help.
  • Slatsy
    Slatsy
    I'm up in Darwin ATM , it's easy enough to do just wanted to get a tool list together but cheers
  • Slatsy
    Slatsy
    anyone have any idea what will happen to my se tuner /efi when I put stock exhaust back on and then When I change back to v&h short shots will se fuel map self chage, looking at my exhaust studs pretty rusted guess I'll have to change them out as well as exaust mounting bracket ,and my pipes are heat wrapped so I'll have to pull that off to access o2 sensors then apparently they need a mounting adaptor , this is such a pain Inthe arse the $700 the local harley shop wanted to swap exhaust is starting to look tempting!, or worse go down the road and stuff exhaust with steel wool
