Online: WideglidingNZ
Torque Settings ( Ask here to get the Answer you want )
  • Tahcam
    Tahcam
    Thought id put this here, as ive used the search button , but i cant find what im looking for ( Hope this is OK )
    Can someone tell me what the torque settings for the handle bar bolts ( 4 located on top ) for a 15' FXDF please? i want to adjust the bar angle up a bit
  • FONTANA302
    FONTANA302
    From the manual:
    Upper handlebar clamp fastener 12-16 ft-lbs 16.3-21.7 Nm
  • Tahcam
    Tahcam
    Fantastic, Thanks for going to the trouble to find out for me...
    The manual is probably the best thing you can buy for your bike. It has everything in it and helps even idiots like me who are hopeless with the tools
