Online: softfat, Rouli
Fatbob headlight
  • fatboblkh
    fatboblkh
    just wanting to know if anyone's changed to single headlight on there fatbob, decided to do mine but not real sure what to get that will fit. After a 5 3/4 in black one , does anybody know if I can buy one that will plug strait in , thanks
    Mate of mine replaced his oem fat bob headlights with a single harley day maker light. Looks and works well.
  • fatboblkh
    fatboblkh
    do you know if it just plugged in or did he have to play with his wiring is what im trying to figure out.If i can get one to plug in i can do it myself, if i gotta play around with wires I'll need someone else to do it as i dont know much about wiring , thanks
  • Buckshot
    Buckshot
    All I can add is make sure you get your wiring straight, the bike runs on a Can-Bus system and if you screw around with non-OEM electrics you ‘can’ open up a tin of worms. Maybe drop Nate at ‘hoglights’ an E-mail? I found him to be a pretty switched on bloke.
  • Aussie XB12SS
    Aussie XB12SS
    Put a Wide Glide light on mine. Plug & play.
  • robots
    robots
    Serge put fatboy light on his bob:
  • DarKasH69
    DarKasH69
    That looks neat. I got a Fatboy Headlight also to fit up.
    Whatever seat he Is running ????
  • DarKasH69
    DarKasH69
    Did you use a Fatboy mount or something else that suits better. Looks good Mate.
  • fatboblkh
    fatboblkh
  • DarKasH69
    DarKasH69
  • fatboblkh
    fatboblkh
    Yeah that looks good, where would I get one like that, did you buy the mount seperate ?   Nice bikes
