Online: B0nes
Freight train headlight ?
  • binnsy
    binnsy
    Theres a guy selling a freight train headlight surround or nacelle if thats the right word.  It is the left and right side only and I was thinking of putting it on an 07 fatboy.  There is no mounting hardware and I believe I need some sort of mounting hardware to fit it to the bike.  Am I correct in this assumption.  ie can I use my original headlight or is there more to it ie brackets etc.  Sorry just not sure .  Dont want to buy it if its just gunna sit in the shed and be no good to me.  Thanks.
  • SoftailSteve
    SoftailSteve
    Have one on my heritage and I used my headlight that was on it
  • binnsy
    binnsy
    Thanks SoftailSteve. Did you need any other brackets etc. ?
  • KiwiRob
    KiwiRob
    The frieght train surrounds from a Touring model won't work to well, if that is what you have, as they are too wide I believe, The sorrounds from the Soft Tail kit, are the only ones that will work properly. 67907-96c was the old part number, but I believe there is a newer version that replaces it now. If you do a seach on this forum, you sould find there have been several threads on this conversion over the last few years, mine included.
    Also beware that there are/were some dodgy, Chinese aftermarket freight train nacelle kits that reportedly didn't fit or mount very well. Why would somebody be selling an incomplete kit anyway?
    I always wanted one for my last fatboy but had trouble justifying the price for the genuine harley one
  • keith
    keith
    Light arrives long before the bike ! On a roadking.
  • KiwiRob
    KiwiRob
    If you have the right soft tail nacelle sides. you will mostly require the well nuts & all the screws that are supplied in the kit. The part numbers are provided with the installation sheet. Google -JO4200 which should have a PDF download for it. Your headlight bucket & parts will fit. - Rob
    Man that headlight is 'different'! Not my cup of tea but it actually sort of suits that bike for some reason.
