Online: imoo6170
Ultraseal
  • Mainey88
    Mainey88
    Done a search on here and couldnt find any info so thought I would post it up..............ever had a puncture in the middle of no where this may be the answer, rang the Perth dealer today and $80 bucks done at my home or his workshop looks like good preventative maintenace to me.
    Has anyone on here used this stuff before, your comments please,,,,,
    http://www.ultraseal.com.au/contact.html
  • shadowhand
    shadowhand
    I've not used it but a good preventive measure is an inner tube.
  • imoo6170
    imoo6170
    I have a mate who used Slime. We found a hole in the tyre when we were at Frasers one day - they way he had parked made the hole stand out -  it looked like a big screw had done the damage and then somehow fallen out. The Slime had filled hole and allow him to keep riding without realising there was a problem.
    I have never personally used it and am not sure whether it is good or bad for tyres......
    http://www.kfvs12.com/Global/story.asp?S=396250
  • hutch82
    hutch82
    I used the slime oneday on a trailer tire and was good as gold until the dudes at the tire shop changed it cause the shit is tough to clean up. Probably wouldn't use it again though.
  • Mainey88
    Mainey88
    used slime a lot in my motocross days and it worked well but that was only for off road stuff, probably would throw a tube in the HD unless I already had a puncture as tubes can create extra heat, I do carry a plug kit in me bag for that middle of nowhere emergency though.
  • Phillthy
    Phillthy
    The balancing beads would have trouble in this stuff.
    Better off carrying a repair kit like Mainey88.
    Father in law used to use shearers glue (like contact cement) in tyres out on the farm.
    Not my style but each to their own.
  • 1elcys
    1elcys
    Yeah mags and tubeless repair kit is better for your rims.
    Isn't putting a tube in a tubeless tyre a bit daft! as when the tyre gets punctured the tube prbably will too.
  • Phillthy
    Phillthy
    Yeh, cant see why I should make the bike wear a condom.
    I don't like them, so why punish the bike?
