Online: obisteve
Pro One Front End
  • BIGGIE
    BIGGIE
    Ive got a pro one front end on my 2000 fatboy softail, I need a shock seal kit or rebuild kit as the seals are leaking.
    Harley dealerships wont touch it as its non genuine (ive called them) and I don't know who else to try......
    Any suggestions?
    Thanks
  • BIGGIE
    BIGGIE
    VIC, but not fussed where it is as Ill get them to ship the parts, im going to have a crack at changing these myself
    You will probably find that they take Harley seals , were in vic?
  • BIGGIE
    BIGGIE
    I heard through a mate they are 41mm but some of the brass spacers? (not sure if this is the correct word) are longer than standard HD ones, which im guessing I wont need to change to fix the leak.....
  • BIGGIE
    BIGGIE
    oh and I live in Wallan (northern VIC)
  • Geoff3DMN
    Geoff3DMN
    Your profile says you're in 'Northern Victoria', if you're close enough to Bendigo then I suggest giving Jase at Hog Doctor in Bendigo a ring.
    They work on all sorts of Hogs, not just recent bikes and genuine stuff like the dealers do, I've had a few things done there and they've always done their best to help.
    http://thehogdoctor.com.au/
    *edit*
    Just realized you posted 'Wallan', you're probably closer to one of the Melbourne shops than to Bendigo - maybe one of the guys down that way has a closer suggestion.
    JDC Customs in Craigieburn ,Jason is the best on your side of down 0415 384 319.
  • BIGGIE
    BIGGIE
    thanks heaps ill touch base with him also
