Online: Far Canal, speedzter
tcb in 2000 softail
  • nato
    nato
    hi guys any know if a 2015 twin cam b will bolt to 2000 softail frame i savvy there is a conversion plate but not sure what else needed
  • Hudson76
    Hudson76
    No. Frames are totally different. I looked at this for mine also. The cost to modify the early frame to fit a later engine would be so prohibitive you may as well sell you bike and buy a newer one. (I know that's not what I wanted to hear either.)
    Better off spending the $$$ on rebuilding your engine. A nice 95/98 CI build and you wont know yourself on it. :)
    Not sure what the deal is in regards to later to into early tc but try Vulcan engineering in the USA
    Thay make the adaptor plates to put all the 88 upto 103 into evo softail frames so thay may make
    Them for the tc aswell
  • nato
    nato
    thanks for the response guys I did find something last night that said dyna engine wont fit softail frame due to rubber mounts its not a repair job both my bikes run I spotted frame and engine online got to thinking could make a good build
