Online: Merv
13 Street Bob Vibe
  • limpn
    limpn
    Hey guys
    2013 street bob with 103
    stage 1 kit with VH big radious pipes
    i cant belive how much vibration goes through the hangers / pegs and frame in general ... i was reading online how there might of been a recall for front engine mount.
    i called my local HD dealer and they have never heard of it being a issue .. ran my VIN with no records of Recalls ...
    it vibrated that much i lost seat bolt....
    going to take it to my local dealer next week to get it sorted ... need to wear a bloody mouth guard...
  • Damo14
    Damo14
    Get onto it mate i have one of the first streetbob's with the 103 and i went through 2 front engine mounts in the first 6 months
  • Speedy
    Speedy
    On a tangent, but inline with H&Hs comment ...
    My 103 has stage 1 / SE Super-tuner, as applied by dealer.
    It STILL pops a little on deceleration.
    Is the Supertuner ONLY any good, for a 'flash tune' .... or is the diligence / ability of tech at dealer, more in play ?
  • limpn
    limpn
    I get a lot of pops sounds awesome but could be to lean :/ was just a dealer tune ..
    The bloke who I'm taking it to next week said he will go over it ..
  • gidgi
    gidgi
    It is my understanding that Dealers configure them with a map which is generic & only covers a limited amount of fine tuning which will be adjusted properly with a Dynotune in the right hands
  • limpn
    limpn
    awesome .. could be the case as i have another issue with the rear rocker head getting so bloody hot it burns my inner thigh.. very uncomfortable riding it.. i think it needs a decent tune .. hopefully Monday will get it sorted
  • Stewy
    Stewy
    Check the alignment of the front engine mount..
    It might need to be shimmed..
    Makes a huge difference if set up properly.
    Search the forum,, there are heaps of posts on it
  • limpn
    limpn
    Thanks mate :) very helpful..
    local harley dealer said and i quote " YOU BOUGHT A DYNA GET USE TO IT "
  • brucefxdl
    brucefxdl
    gday limpn,bought an 07 low rider a while ago.on the 2 hour ride home,the vibes in the right peg killed my foot over 95 kmh.checked the front mount and found the outer mount section had sagged on to the inner piece.fitted a new mount [ on the dealer ] and reduced the vibes by 85 % then shimmed the inner section back from the frame a bit and rdduced another 10% of the vibes.as this is my first proper harley ,i have nothing to compare it to but its good now. if we told our customers to " get used to it " they would probably shove the machine up our arse sideways.hope this helps a bit.cheers
    Find a different dealer or someone different at the dealer as that attitude should be left at home. I would crack the chits with a dealer saying that to me and go straight to the dealership manager.
  • limpn
    limpn
    cheers guys
    this is the same dealer 3 years ago told me " i would never be able to afford a harley and to stick to my jap crap"
    words from the salesmen mouth .....
    i now drive 2hrs to sydney cbd and get my parts .. instead of the 20min drive to those local rip off bastards..
    they just quote me 2k for a service and fit and supply mid controls :O
  • limpn
    limpn
    got bike back yesterday... put polly bushes in trees got rid of 80% of the vibration i was getting.. just a little bit now in the pegs but its bearable :)
