Online: Far Canal, Stuart
Rear Pillion Seat Screw
  • T-1000
    T-1000
    Howdy All,
    Would like some advice..... Can anyone give me some ideas as how to properly secure the rear pillion bolt....I have lost 2 of the f#kn things on one ride one on the way there and then on the way back.
    I have a Breakout  ...the screws are tighten  really good when starting out and then the thing gets  loose along the way  at times when I check I am able to re tignten but have lost 2 so far.....I regulary change from solo to pillion...so dont want to lock tight it...
    thanks
  • Geoff3DMN
    Geoff3DMN
    Maybe try one of these? They've got a nylon retaining washer that isn't on the stock bolts.
    http://www.revzilla.com/motorcycle/drag-specialties-14-20-seat-mount-nut-for-harley
  • T-1000
    T-1000
    Appreciate the feed back but its the screw/ bolt that you screw in ontop of the fender to hold the rear pillion seat like those knurled ones.
    T
  • HIALEAH
    HIALEAH
    I have never had one come loose, not sure about others, It does seem strange though, Maybe look at replacing the nut on the Guard and try that.
  • Methuselah
    Methuselah
    Try Locktite thread lock. I use it every time I undo and do up a screw/bolt on the bike.
  • Smokey61
    Smokey61
    Loctite blue.
