Online: Far Canal, Stuart
Flipping mirrors Dyna streetbob 13
  • Romo
    Romo
    hey guys ive got some new mirrors and am looking at mounting them under the bars on my Dyna. The left side is fine but the blinker assembly seems to be using up the right side mount? Anyone know the part number I need to move the blinkers so I can do this. I still want the blinkers near my hand grips also. A friend has a streetbob special and he has the brackets I need already installed.
    Thanks in advance!
  • mitch199
    mitch199
    Maybe just call the dealer mate, I'm sure if you tell them you need street bob special front blinkers stand-offs, they'll help you out!
  • Romo
    Romo
    Thanks man. I did try my dealer recently and was met with the response: 'What's the part number I can't help you without the part number'. I'll try again today hope I get someone a bit more helpful
    Also grab a Catalouge from the dealer as they are free and should have the part you are looking for in them.
