Super tuner cable kit wanted
  • Paulb
    Paulb
    I'm hoping I can borrow or buy a cable kit to sort out my screaming eagle tuner. I have a  09 softail and keen to get sorted, happy to buy? Perth WA
  • grahamjb
    grahamjb
    Paul
    Check your PM
    GB
  • Retroman
    I'm in Perth's northern suburbs , with a set
    Probably best for you to order a set from ebay Australia , Peter Stevens sell them for a posted to you cost
    Just make sure you get the correct model year for your bike
    2001 t0 2010 Softails were the same ( and the same as all other models until 2011 )
    The Softail ECM and wiring changed in 2011.
    You ned the 2001 to 2010 cables
  • See you NT
    See you NT
    Can anyone out there point me in the right direction in finding the 2001-2010 cables for my '09 Fatbob? All I can find on the net is the 2011 up cables. Will go and ask the local thieves at the HD shop today.
  • Retroman
    ebay Australia search for Harley tuner/cables should turn them up at Peter Stevens
  • See you NT
    See you NT
    All good mate. Ordered a set through the local Harley shop.
