Online: Merv
Front suspension improvement for 2015 NRS
  • Gunn
    Gunn
    After some real input of setting up the front suspension more for performance and handling. There seems to be a lot of suggestions around for looks.
    Coming from a Hayabusa to the 2015 Nightrod Special has been a learning curve in getting confidence in its cornering abilities. I am about to go with a set of Avon tyres which should help - but the front is rather "mushy" with no real feedback.
    Some have recommended the progressive springs - but they generally ride around town. I have enjoyed track days on the Hayabusa and would like to get the Nightrod out there. Have got the Akro exhaust, SE cleaner and an incredible tune – so there’s no issue with torque or power, just handling.
    What have other members done to sort out their front end - as it seems a fairly common complaint.
    Appreciate some inputs. Thank you
  • RodADELAIDE
    RodADELAIDE
    Gunn,
    I had Walter at YSS here in Adelaide rebuild my front end and supply a pair of piggy back fully adjustable rear
    shocks and have to say the ride is chalk n cheese. Although im still playing around with my solo settings ATM im quite satisfied with our two up ride.
    Well worth spending some coin to achieve what the factory didnt do. I plan on getting an aftermarket swing arm from the UK later which will help the
    suspension work better as well. Then may be carbon composite discs. ( All in weight reduction...)
    Cheers,
    Kym C
  • Gunn
    Gunn
    Thanks RodADELAIDE - what did YSS do to them - just the progressives and oil ?.
    For the rear I am about to try out the Arnotts with adjustable rebound etc. A friend in the States who has come from a sportsbike background said that they worked out well for him and may suit me as sometimes I have bag on the back travelling and sometimes two up.
    Regards
    Steve
  • Dusted
    Dusted
    What did you end up doing?
