Online: obisteve
fork stem
  • shfunky
    shfunky
    I noticed some time ago that the exposed part ot the fork stem that comes through the lower triple tree is corroded. I didnt really worry about it but a mate saw it and said it shouldn't be like that and could be corroded futher up the stem also. I have looked at other fork stems since and cant really see others as bad as mine. My bike is only 12 months old but I'm sure it's been like that since purchase.
    Anyone seen this before?
    any pictures?
  • shfunky
    shfunky
    Will take some tommorrow and post.
    g'day mate... thought that was what you were referring to.. hence request for photo. Mine is same and been like that for as long as I can remember. Also seen a number of other bikes like it. Might ask the question this weekend!!!
  • TNT
    TNT
    Mine's the same, noticed it not long after it was new
  • PigironBob
    PigironBob
    My FATBOB got the same too.
    Maybe we should take out a class action against the rusty phucker?
  • shfunky
    shfunky
    Posted same on the yank forum and several people say the same. One mentioned that the stem is a press fit so the corrosion should not go any further. Might use a little wet and dry then apply a little primer and paint.
  • Deadly
    Deadly
    Now thats confidence in a "press" fit, a circlip to hold it all together.
    You do know these bikes have a corrotion warrenty
  • shfunky
    shfunky
    What do you mean by "corrosion warranty" ?
  • 1elcys
    1elcys
    What warranty! the Harley warranty is a myth.
  • Phillthy
    Phillthy
    Mines the same.
    Yep the warranty and after sales service is a myth.
    Customer relations is also a myth over here.
  • 1elcys
    1elcys
    Mine are rusty on both HD's.
  • Phillthy
    Phillthy
    Rust in stereo.
  • Mainey88
    Mainey88
    mine is rusty  , dont look under there much.....should be able to clean it up I reckon.
