Online: tussuck, speedzter
Forward Pages/Controls
  • Louch
    Louch
    Just picked up a 1996 Dyna Wide Glide. When I try to reash the front pegs/controls I'm bout 2" too short. What options do I have to correct this?
    Cheers, Gustav
    Please be gentle on me this is my firdt Harley.
  • chopa
    chopa
    Maybe someone has put extensions on the forward controls
    Take it to a dealer so they can tell you exactly what type of forward controls they are . You may be able to get some reduced reach type .
  • Colstah
    Colstah
    They look standard to me, maybe the sneakers are the go! Sorry can't be more helpful. <img src=" border="0" src="/DesktopModules/NTForums/themes/_default/emoticons/smile.gif" />
  • chopa
    chopa
    The seat looks like the problem to me
  • Speedy
    Speedy
    Yep ....
    Seat looks to be set up for Lurch and his mates !
    ( Fatbat ... take yourself to the naughty corner )
  • chopa
    chopa
    How does it handle with the wider front wheel???
  • bobby bob
    bobby bob
    sporties for shorties.
  • Geoff3DMN
    Geoff3DMN
    There are a couple of things you can do to fix your problem, the first is a reduced reach forward control kit, the second is a reduced reach seat.
