Online: Stuart, Hilly
Conversion kit help (yes i've read the main thread)
  • fmacdonald
    fmacdonald
    G'day Noctm
    Are you doing it yourself and is the bike EFI?
    Just went down the same process using Hammer performance 1250 kit with factory 883 heads and using a PowerVision to must say the bike is lots of fun to ride.
    If you get really bored I have a timelapse of the conversion https://www.youtube.com/watch?v=ynYrIgOM9to
    Only surprise I had was that I need to upgrade the clutch as it could not cope.
    PS Cost was about AUS$600 for the Power Vision and US$680 for the 1250 Kit including gaskets
  • fmacdonald
    fmacdonald
    G'day Noctm
  • noctm
    noctm
    Hey mate thanks a lot for the reply.
    Yeah I will probably do it myself and probably enlist the help of a mate with more mechanical experience than I just to be safe. Bike is EFI and I have the SE Pro Super Tuner
    Didn't realise Hammer did the same sort of kit at around the same price - i had only seen their complete conversion kits which seemed to be in the several thousands. Can you please provide a link to the Hammer kit you speak of?
    Did you just upgrade the clutch spring or more of the assembly?
    So there's no issues that should arise as far as you're aware by using the existing 883 heads?
  • fmacdonald
    fmacdonald
    This is a great read http://www.hammerperf.com/883conversions.shtml as it does through the pros and cons of each option. I am not after a racing bike (owned those before :) ) but did want more performance than the 883.
    The main downside is that choosing to use the 883 heads means you need to buy dome pistons and this means you may have issues later if you want performance heads. So it is best to work out how much performance you want within budget and do it all in one go.
    The swapped the spring to an SE one and it still slipped so I swapped the complete pack to a Energy One kit. However it seems that lots of people have no issues.
    Also check out http://www.nrhsperformance.com/ekit8831200.shtml , similar price
  • noctm
    noctm
    Okay great - i'm not chasing crazy numbers so in terms of performance I'm pretty much after whatever the basic 883 - 1200/1250 conversion kits will give me.
    In regards to the pistons - the S&S kit has dished pistons and the Hammer kit has domed pistons, is the story the same here if I ever did want to change out the heads?
    I'll guess I see how I go with the existing clutch and see if I have any dramas, and then upgrade the spring and then the plate if need be.
    Thanks again for the info mate. Any extra tid bits you think will be helpful please feel free to add them in I am keen to hear it all.
  • fmacdonald
    fmacdonald
    Also when I spoke to HD re the SE Stage 2 883/1200 kit at my local dealer in Sydney they said they would discount the price of the tuner as I did not need that. This is the kit I am talking about
    http://www.boardtrackerharleyonline.com/harley-davidson/screamin-eagle-pro-sportster-883cc-to-1200cc-stage-ii-conversion-kit-29836-10
  • asps91
    asps91
    fmacdonald, my dealer said the same to me aswell when i enquired. Harley Blacktown?
    Im in the process of doing this as well. I think im going to change out the heads though, its just been hard to find some. Was looking at the screamin eagle (even then i would have to get the breather bolt holes drilled and tapped as im carby and the current heads are efi suited), but at almost $1k for the heads i could get the 883 heads ported and valves upsized. Still tossing up whether to go all out or simple. I really need to see one that is running stock 883 heads up close.
  • fmacdonald
    fmacdonald
    Yes, it was Blacktown :) If you are near place you are welcome to pop by
  • fmacdonald
    fmacdonald
    @#ck I need to learn to read what I write before hitting submit.
    Yes, it was Blacktown :) If you are not to far away you can pop by and suss out my bike (PM me). I know what you mean about the heads, ebay Australia lets us down compared to the US. I would like to upgrade to Brembo brakes but they are just too dear locally.
  • noctm
    noctm
    asps here's a picture of an 883 converted to 1200 with the stock 883 heads (S&S kit with a different fin profile on the barrels, some kits have the same fin profile so you can't even tell the difference):
    so in your guys opinion, would i be better off going to SE kit that has heads included, or does it not really matter much if i just go the kits that use the 883 heads and dished/domed pistons?
  • fmacdonald
    fmacdonald
    Noctm from what I understand they are similar of you are happy to stop there but if you then wanted to add bigger cams etc the 1200 head is better.
    Could you blokes get headwork done locally? There are a couple of reputable places in Sydney
  • fmacdonald
    fmacdonald
    When I looked at pricing a few months ago the options came to
    Hammer Kit, Gasket Kit, Pistons Pre Gapped and Postage ~ $1000 AUD
    SE 1200 Stage 1 Kit with heads but no tuner (part number 30003-10) is about $1800
    SE 1200 Stage 2 Kit without heads but with tuner (part number 29836-10) is about $1800 less $500 for the tuner
    Not saying it is correct but I went with Hammer in part as I wanted them pre gapped as it reduced the work for me (yes I am lazy)
  • Howard
    Howard
    If any of you guys who are thinking of upping your 883, I'm in the process of upping my 1200 to a 88 inch hammer and its going to cost shit loads, heads, cams, lock up clutch etc, etc. So if anyone wants to buy standard 1200 cylinders, pistons heads etc at a very good price let me know. It will be quite a few months as Hammer are letting me do a lay buy. nButb if anyone is interested let me know.
  • noctm
    noctm
    Sorry about the double post but figured this was worth a separate entry as opposed to editing.
    Just spoke to Frasers - they've got what they call a SE 'Torque it up' kit. I've been quoted about $2500 including fitment. The kit includes just about everything except heads, including cams, clutch upgrade etc. and according to them is a much better way to go than the standard SE 883 to 1200 kit - better numbers and so on.
    After calling around and reading up, i think this is the way I'm going to go - seems to be the best route for bang for buck.
  • fmacdonald
    fmacdonald
    Did they give you the part number? Sounds good. There is also the SE Stage 4 kit ... hmmm nice
  • fmacdonald
    fmacdonald
    This is the stage 4, http://www.harley-davidson.com/store/screamin-eagle-stage-iv-street-performance-kit-–-sportster-models--black-non-highlighted-heads (US price)
  • asps91
    asps91
    Be good if i could go this way, unfortunetly i have a 1992 carby so a bit of machining is needed to fit late model heads.
  • Howard
    Howard
    Hi asps91 and noctm,
    asps91 didn't get your pm so send again if you are interested to h.gill@murdoch.edu.au (same to yo you noctm, and we must catch up as you live just down the road). I have no idea how much 1200 barrales, pistons and heads ertc are, but if you are interested half price plus postage? Noctm will deliver or you pick up and get Ando to to do the work, he's good and lives just down the road. If it has to be quick will sort it out, but rather pay for the hammer upgrade slowly. But f a firm offer will get the 88 inch ordered.
