Online: beaglebasher
Will '06 dyna exhaust fit '96 Dyna
  • chopa
    chopa
    Will an '06 Dyna exhaust fit a '96 Dyna ??
    Just wondering if the 02 bungs are the only difference and if so if I plug the bung holes up will they fit
  • Hudson76
    Hudson76
    I believe the flanges are the same but the brackets to support the exhaust on the bike will most likely need to be modified or fab new ones.
    And yeah just plug the O2 ports up.
  • chopa
    chopa
    Thanks for the reply. I will give it a try
