Wide Glide 2" tank lift advice needed
  • SRV72
    SRV72
    OK, so I've been playing around with the idea of doing a tank lift on my FXDWG. I took the front bolt out today and chocked up the tank by about 2 inches. I think it looks good and give better clearance for cleaning the rocker covers etc.. Below are some before and after pics from the mok up. Anyway my concern is if I raise the front end of the tank how will this effect fuel consumption? The way I see it the fuel gauge will be thrown out indicting that I have less fuel then I actually have but as the fuel is drawn from the rear of the tank I should be able to get more km's out of a tank?? I only get about 300km out of a tank and dont want to make this worse. Thoughts????
  • Blackmagic
    Blackmagic
    I am thinking of doing that to my Low Rider
    Moz
  • Sugar
    Sugar
    Done it to my breakout, found that light comes on a bit earlier. filled up with 0kms to go low fuel warning and only took 16ltrs. had travelled 295kms. works fine for me.
  • SRV72
    SRV72
    Yeah the lowrider would look much better with a small lift to the tank. Dunno why HD has designed them to sit so low? Hey mate how do you do those photos with the bike in colour and back ground in black and white? Is it a special programme? Does it cost?
    Cheers,
    Dan
  • Mr.Mow
    Mr.Mow
    No0 thoughts on that.. but you wanna sell me the stock low sissy bar off your wideglide?! :)
  • Sparra
    Sparra
    What's the colour of that Lowrider...Looks great.
  • Sparra
    Sparra
    Thanks mate,many years ago I had a 750 bonnie that I had painted and it looked very similar...The Black Magic colour looks different when you look at it on a dealer web site.
    Cheers...
  • berserker
    berserker
    I got less range too with a 2" lift on my superglide. looked fucking awesome and so much easier to clean but the range was a killer for me. Not just the gauge reading as that's expected anyway, but i filled up at 200-215kms about 14 litres every time with the kit. Usually she only needs 10 litres max for that sort of range and it went back to this the second i removed the kit. Ended up getting rid of the lift kit for that reason. As to how it loses range...well i gotta admit it has me baffled. The only thing i can think of is is when you put too much fuel in, like above the plate, the bike expels the little bit of excess from the underside. Perhaps the lift kit affects that system somehow? But that's nothing more than a wild guess.
  • Blackmagic
    Blackmagic
    I would say that because the front of the tank is now higher than the filler point/gas cap area,
    it can't be filled properly past that point, so you are loosing the capabilty to fill the tank.
    Probably loose a litre of fuel storage.
    Moz
  • SRV72
    SRV72
    Well I guess that has made my mind up not to do it then. I couldnt have less milage per tank than I currently get. Although I have seen a more expensive lift that lifts both front and rear of the tank but probably not the same look.
  • Methuselah
    Methuselah
    I know this is an older thread but I have just put the 2" lift in my Superglide. It looks good and it gets more air over the motor. It also gets my SE heavy breather away from the tank. Before it only had a 1.5cm gap with the chrome cover on it.
    As for less range, the gauge goes down faster but I have not lost any actual range. I just go further than the kilometres to go says.
    I went past zero k's to empty the other day and could only squeeze 13.86 litres into it, and I mean squeeze! So somewhere in there was just about another 5 litres or thereabouts that the gauge no longer reads.
    Also when I first fill up it now says I have got around 370klm to empty, where before it used to say 400 to 420.
    The jury is still out on it though because the one thing it does do that really pisses me off is my helmet tries to rip off my head at 110kph. The speedo seems to catch more air and rather than direct it around the speedo it directs it straight up and under the lip of my helmet. It didn't do that before till I was well on the wrong side of 120.
  • Daggs
    Daggs
    Made and fitted one, took it off, grew to hate the look
