Online: John.R, Hilly
106/107 BIG BORE KIT
  • Vasilis
    Vasilis
    Good evening,
    I am considering to install the 106/107 big bore kit (cylinders and pistons) to my 2007 FLHX since I observe an increased oil consumption but I do not wish to make any head work.
    My current set up is the following:
    1. S&S stealth air cleaner
    2. S&S Power tune headers
    3. Vance and hines slip ons
    4. S&S 551 easy start cams, S&S quickee push rods, redshift dual piston cam chain tensioners and axtell bypass valve.
    5. Thundermax ECU
    Since I do not wish to do the heads should I replace anything else like the S&S cam support plate or oil pump considering engine reliability
    Assume that I will gain also a minor performance in HP/TQ.
    If any of you have done something similar in the past please share your experience.
    Thanks in advance.
    Vasilis
