Online: baldy1450
Demon Heated Hand grips.
  • malibu_lxi
    malibu_lxi
    Hi All,
    Anybody use these if so what are the Pros and Cons.
  • berserker
    berserker
    I assume you are talking about the symtec heat demons. I have them on my dyna, the pros are they look subtle, they look as if theyre part of the control housing and they have an adjustable heat setting. The cons are if it is really cold, they don't do much. Anything 10 degrees or less the heat is not very noticeable. Basically if it is really cold, your hands will still be cold, but not so cold that they go numb. Overall im happy with them, but they're definitely not the warmest ones around.
  • malibu_lxi
    malibu_lxi
    Ok sweet thanks for that.
  • malibu_lxi
    malibu_lxi
  • cattleprod
    cattleprod
    I've been using these for the past 14 months.
    Normal riding speeds around town in 2c conditions, bloody wonderful. Open road at 110 plus, finger tips and thumb still get cold.
    Palm of hand keeps comfortable at any speed and weather condition, even in the wet.
  • Rick1310
    Rick1310
    I have have mine a few years now & the y are great & you can use any hand grip which is good too.
