Online: Hilly, speedzter
HD audio headsets
  • firerymark
    firerymark
    Hi,i have a 2016 Ultra Limited (Rushmore) it came with two of the standard HD headsets (rider/pillion). does anyone know if you can get HD (or other brand) headsets with smaller speakers, the speakers in these standard HD headsets are just too big and don't fit my helmet (Shark), i don't really want to get another helmet so that would be the last option and hopefully not the only option, was wanting to keep the cable connection and not got to bluetooth as that has its own problems.
    thanks in advance for any info or feedback.
  • FLIPDOG
    FLIPDOG
    surely you can get alternative speakers somewhere, be resourceful
    most shark models have removable tabs in the ear area to accommodate speakers     (or large ears) haha
  • firerymark
    firerymark
    I have considered cutting some of the liner out, just didn't want to do that and then find out there are other speaker options.
    thanks.
  • firerymark
    firerymark
    I don't have large ears, there are no removable tabs in the helemt's ear area, so i will probably have to cut out some of the liner.
    thanks anyway.
  • Nomada
    Nomada
    Pull the liner away from the foam insert and make the hole in the foam larger ever means you want.
    I used a pen knife.
    Place the speaker in between the foam and liner.
  • firerymark
    firerymark
    thanks, I will have a look at the weekend when back at home.
