pre oiling an oil filter
  • Odin
    Odin
    Changing oils at the moment, jut curious.
    How many of you pre oil your oil filter or do most just screw the oil filter on.
    If you re oil, how much do you put in?
    Normally I always do with cars /bikes if you it can be done just fill filter to top with what ever oil your using
    Most of the time it's all sooked up in the paper element and put some on the oring , and the oil light does go
    Out a lot quicker or gauge up
  • brucefxdl
    brucefxdl
    been changing oil filters of various types and positions for 40 or so years on a daily/weekly basis. most of the time, if the filter sits verticaly i prime them.but when i dont it doesnt make any noticable difference.if the oiling sytem is up to sratch it will come up to pressure in a very short time.if the filter is horizontal or vertical but up side down the oil will run out before the seal is contacted,so theres not much point in priming them. hope this helps cheers
  • markwoumla
    markwoumla
    In the big picture, priming or not priming (if the oil system is performing as it should), I dont believe would be detrimental to engine wear .. I suppose it comes down to , what your Grand daddy told you... Now, if the engine had been drained of oil and sitting for a long period, priming the oil filter, (and other pre starting oil circulating procedures),, would be advisable ... That being said, I prime the oil filter on the Harley. If you fill it up with oil and let it soak in, (put the bike on the jiffy stand so its leaning the right way), it does'nt make a mess. And the main reason is, my Grand daddy told me to ...
  • Hound_Dog
    Hound_Dog
    I always prime. What does it take and extra 10 seconds? Why wouldn't you?
  • brucefxdl
    brucefxdl
    i'm intrigued ,fill the filter 7/8th full [or there about ] then turn it on its side,move it into positoin and screw it on till the seal contacts,with out loosing oil ?
    I ALWAYS fill the filter at least half way....you would be bloody surprised at how much oil the filter actually absorbs.
    At the very least by priming it your minimizing any oil starvation issues when starting the engine for the first time.
