Online: baldy1450
Excess Stock Clearance
  • nathan_ford
    nathan_ford
    Hey all,
    I have some brand new, older style 7” LED headlights that I wish to move to make way for the newer design units.  These units are as powerful as HD Daymaker lights, come with a 3-year warranty and can be delivered immediately.  There are only limited numbers of these units available, so get in quick.
    Specifications
    • 7" Headlamp with black or chrome backplate
    • Features a single top-mount low-beam projector lens, a large bottom-mount high-beam projector lens and 2 “D-shaped fill-light lenses
    • Horizontal "D-shaped” lenses focus light into a pool in front of the motorcycle, and separate high beam and low beam projector lenses provide a focused beam of light ahead
    • Solid-state LEDs are designed for long life, and the shock-and vibration-resistant lamp assembly mounts into existing light housings
    • Installation is quick and easy, and the plug-in lamps connect to the factory headlamp wiring
    • Power: 45W
    • Voltage: 10-30V DC
    • Leds: CREE
    • Lumens: Hi-3600lm, Lo-2400lm
    These are priced at $240 per unit (a saving of $50 a unit).  Free shipping still applies to anywhere in Oz.   No further discounts apply.
    For more info, please click here: http://bit.ly/1pNmdmy
  • nathan_ford
    nathan_ford
    Ok all, only black 7" versions left. The chrome is all gone.
    Cheers!
    Nate
