Online: GGUser761
Softail swingarm
  • ls1sandman
    ls1sandman
    I need a swingarm for a 2003 softail  Duece  so I'm wondering whether a later model will fit
    If they differ to later model ones. How do they differ?
    You can use 2000 to 07 before thay went to 200 tyre , you can't use later there about 10 mm wider won't slip into the frame
  • ls1sandman
    ls1sandman
    Ah thanks for that. I did try google but obviously I was no good at that
  • ls1sandman
    ls1sandman
