Online: GGUser761
Breakout frame
  • inmate
    inmate
    Hi all, im not really in the know with this kind of stuff, But my brother found a breakout on an auction site, its written off.The frame has a big kink under the engine from a hit. The bike (seems) fine in most other aspects, He wants to know whats a good replacement frame to use and can it be registered as a harley. or just registered as some custom. hes in qld but the bike is in vic or nsw i think. I seen some frams on VPW that can take the breakouts 240rear.
  • inmate
    inmate
    Thanks for the reply mate, yep i'll tell him to email VPW or call them to see his options. cheers
    edit-
    Called VPW, they dont have a frame for the breakout. Spewing, Aparently building a custom bike you cant use all harley parts or have it look like one.
  • 06 Softail
    06 Softail
    Just throwing it out there....
    Is it possible to contact Harley Davidson Dealer or someone in that industry who is able to order a new breakout frame with new identification tags etc?
    Then it might be a case of transferring all parts over to the new frame.  I'm not sure what else may be involved going down this path, but it might be worth a shot.
    Yep you should be able to get a new frame from Harley with same vin you have to cut the frame neck of give
    That to them and a bundle of cash almost did this with a softail frame but at the eleventh hour Harley Aus couldn't supply it to the Dealer , us had non left even though it was still available so I got a phone call from a very stressed out parts man
    Lucky I hadn't cut off yet but had paid for the frame Which was refunded
  • inmate
    inmate
    Thanks for the idea fellas, ill head in to harley and ask the question. he has bought the bike so no going back now, was a good buy if he can sort out the frame. he has contacted somebody who repairs the frame then ICV but the genuine frame swap option sounds a ton better.
    I don't think there's any point to contacting anybody about repairing the frame. That frame cannot be registered again.
    Good luck but there's a reason he probably got "a good deal" because it's either for spare parts or a lot of stuffing about and cost to either get it back to being a regular harley or a custom.
  • inmate
    inmate
    If the frame was to be repaired, it wouldnt be registered under that vin. It would be an Individually constructed vehical. with a few changes. Thats what im told anyway.
