Online: Humbug
Mini Half Moon Floorboards
  • TJU
    TJU
    Gidday Folks ... was wondering if any good people out there in Forum Land knew if it was possible to fit Mini Half Moon Floorboards to a Softail frame , FXSTS 99 Frame to be exact .
    I know from the catlologue you can get them for FL Frames but havent seen them for the Softail FX Frames ... i have a 99 Springer Chopper / Bobber that i wouldnt mind trying a set on for both looks but more importantly vibration reasons ... its not a brutal vibration but if there were small boards that would fit then it might make the ride that little bit more enjoyable .
    Curently have the Old School Retro small foot pegs on the old girl which does suit it but like i said just wanted to see how it would look and feel with Floor Boards ... BUT dont want to make any major mods ... hopefully pics will come through .
    Tim .
    I'm sure you should be able to adapt a set tim or try a peg set with striups on your forwards
  • TJU
    TJU
    Found a half decent set through Custom Chrome so might have a gander at
    Them ... tbey mount off the standard peg mount ... but thanks for the reply though , cheers .
