Online: softfat
Red Light On Dash
  • Tahcam
    Tahcam
    Hi Guys, got a New FXDF FatBob ( only 220Kms now ) , took her for a spin tonight, and noticed that the red light was coming on 5 mins into the ride! Now i did some searching on the internet , and it suggests Blown Light Globe! The problem i have is that being the 15 model, it has LED Rear taillights, i have LED Headlights, and the blinkers are all working! What could be going on?
    It's under warranty? I'd never fault find or piss with anything while it's under warranty. Take it back...
  • Jetta
    Jetta
    If you are talking your Security light. Try your spare fob and see if the light still comes on. Sounds stupid I know
    Had the same issue with my bike the other day. Have to take the FOB in for a check up.
  • BDA103
    BDA103
    Next time you notice it's on try pushing the front brake lever forward for a bit and see if it goes out. Had this issue myself where the front brake master cylinder doesn't return all the way out by a poofteenth and then the air pressure when moving at speed pushes the lever back because of the small gap. This releases the front brake light trigger switch to on and after 2kms of this the BMS thinks the brakes have been on the whole time and throws a code and illuminates the dash warning light. Might not be your issue but it certainly gave me the shits trying to fault find it on mine!!
  • Tahcam
    Tahcam
    Hey thanks guys, I'll definitely give those options a go first, trying to get the bike in for them to look at, ( so they can leave it on the floor for a day ) is something I'd rather avoid at the moment...
  • Drac
    Drac
    Did it come with led headlights because they dont draw as much power as the standard globes and system may not be detecting them
  • JFE
    JFE
    Tahcam, you brought it new? So it has warranty. Just it back - they might recognise the issue easily. If longer, most dealerships will have a demo or some such that you can borrow. Use it as an opportunity to enjoy someone else's ride, knowing you will be back in one of the best cruisers out there soon -- a Fat Bob!
  • chriso
    chriso
    check the fault codes man..... after ya check the brake lever cause i to had same issue
  • Tahcam
    Tahcam
    Yeah , i have it booked in for Saturday, they'll whack the computer on and see what it says... I hope its not much... Ill let you know the outcome!
  • BDA103
    BDA103
    And..........was it the switch?
  • limpn
    limpn
    i have a 13 bob and i was told you cant check the codes you have to connect the computer to see the faults ??????
    also a faulty earth can cause the light to come on.. check negative terminal on battery is tight .. was my mates issue
  • Tahcam
    Tahcam
    Sorry for late reply, Faulty Earth was the problem... all fixed now
