Online: beaglebasher, tussuck, Hilly
Accessory power source softail
  • me_ashman
    me_ashman
    Hi, need some help finding a reliable ignition/ accessories power source on my 16 FLS slim. Anyone here that might know?
  • me_ashman
    me_ashman
    Thanks. The two spare wires I found behind the nacelle is on ignition and it seems unreliable as it loses power. Can't figure if it's a bad ground or it's on the ecu/canbus. I'm trying to power my tracmax module and gives a signal interrupted error.
    It runs fine if I give it power straight from the battery but I want it to switch with the ignition.
  • gidgi
    gidgi
    All I done was buy a dual spade type fuse from supercheap , so you buy the same Amp rating for the one your replacing .eg: Acc fuse, or which ever one you use This new spade fuse also has a piggy back fuse with a small length of wire which you use for your power source Ive had this setup on mine for a couple of years, it does take up a little extra room in the fuse box but it squeezes in my Roady cheers
  • Pedro123
    Pedro123
    Just fitting an accessory port to my Sporty and the fitting ir on nstructions mention a 15amp accessory connector under the left hand side cover on the Softy
  • samuraidarryl
    samuraidarryl
    Man this is so cool. Thanks. I'm looking at wiring up a dash can to the accessories power. Really gives me some ideas.
