Online: GGUser744
Low rider 3degree rake kit
  • Low 99
    Low 99
    Hi I have a 99 low rider and I wanted to put a 3 degree raked cup kit on the bike ..has anyone used these kits and are they a good mod ? My bike has Moulded cups  and I need to use a longer stem that comes with the kit ..I don't want to use my bottom triple clamp and was wondering if one from another model will fit.. ?
    Any help appreciated
  • chopa
    chopa
    Try this parts finder
    http://partsfinder.onlinemicrofiche.com/capitalhdspares/showmodel.asp?make=hdmc
  • Low 99
    Low 99
    Thanks for the info..ill check them out ..I was also toying with the idea of lacing up a 21" front rim as well as going with longer fork tubes ...thinking about 4" overs
  • Low 99
    Low 99
    Thanks for the for your input..I've done some googling on trail and rake and I don't want the bad handling traits by adding the longer fork tubes..
    I have progressive springs in the forks and have played with them a bit and I'm happy with the the results so cups it is..
    Thanks guys..
    I will post some before and after pics when completed ...
  • Low 99
    Low 99
    Cups ordered today from Vulcan
