Online: John.R
LED Indicator Inserts - New Product Release
  • nathan_ford
    nathan_ford
    Hey all,
    We've released a new product line to our range.  LED indicator inserts.  These replace your standard incandescent globes with LED inserts.
    These hare been engineered to be as bright as possible. The indicators are available in Amber and come as a complete set, including 4 LED indicators & LED Load Equaliser. We have these available in 1156 (single function) and 1157 (dual function) styles.
    These are available for both Bullet & Flat (with included adaptor) style indicators.
    These indicators fit into the standard Bullet or Flat style housing. With the 1156/1157 base on the indicators, installation is as easy as removing your exiting indicator bulbs and plugging the new LED light in.  Installation takes 2 minutes and can be done without tools.
    As LED's take less power to run the normal bulbs, a LED load equaliser may be required for the indicatiors.  The LED Load Resistor is included in the bundle kit.
    A video of the units is below.
    More info on the kit is on our website:  http://bit.ly/1VBny9w
    Any questions feel free to ask.
    Cheers! Nate
    They are processing this video and it says I should check back later...
  • nathan_ford
    nathan_ford
    Sorry all, bloody YouTube is slowing us up for some reason.  I'll have it fixed shortly and post up a new link.
    Cheers! Nate
  • nathan_ford
    nathan_ford
    Right fixed the issue. updated video here: https://vimeo.com/156777409
    I've also updated the original post.
    Sorry for the screw up guys.
    Nate
  • mickle
    mickle
    Just ordered a set, let you know how they go China.
  • nathan_ford
    nathan_ford
    Thanks Mickle!  They'll be shipped on Monday mate. I'll send a tracking number down to you just before they go.
    Cheers! Nate
  • PaulW
    PaulW
    Hi,
    What if I only want 2 as my 48 already has LEDs on the rear?
    Can you explain the difference between the 1156 & 1157 styles
    Can you explain when the load equaliser is required (ie would my 48 require one?) and how its hooked up
    Thanks, Paul
  • PaulW
    PaulW
    That helps a lot, thanks Nate
  • mickle
    mickle
    Ok got the new LED indicators fitted up tonight, as easy as twisting out the old and twisting in the new, as mentioned no need to fit
    the equaliser on my 2015 Ultra so all up 10 minute job to do the 4. I was a bit worried about these as I have seen similar type LEDs
    on others bikes and they just don't seem bright enough if you have the tinted lenses from some distance away, anyway I had no need to
    worry as they are very bright to the front and rear and look very good in the housing, thanks Nathan.
  • mickle
    mickle
    Mickle
    Are they bright and easily visible in daylight? I've got tinted lenses too.
