Screaming Budgie Street Performance Tuner
  • groover
    groover
    Just bought a 2016 Ultra Glide.
    Dealer is offering a Street Performance Tuner. Is it better than the Pro?
    Can the idle be adjusted and the exhaust flapper valve be disabbled?
    Can the mapping be done by running up the street or a dyno?
    Is it upgrade friendly with a stage 5?
    Am I better off with a TTS?
  • EBT
    EBT
    Hi Groover,
    The street tuner really wont be any use to you. If you are looking for a cheaper entry into the tuning of your glide you can buy a Dynojet Power Vision Licence key. Your Dyno shop will be able to tune any engine combo you choose. I noticed you are in Sydney. Give Cow and Jim a call at LA Cycles a call. ( 02 9608 3572 ) They will be able to help you with all your performance and tuning requirements.
    Cheers,
    Brian.
