Fitting cam bushes
  • Ninnyhere
    Ninnyhere
    I have a 1942 WLA Harley. I need to have new cam bushes fitted to the engine case side. I am having difficulty in finding someone who can fit the bushes and line bore them so they are set up properly.  Can any one suggest someone who can do this for me for a reasonable price. supply and fit bushes plus line bore or I can obtain the bushes if needed.   Thanks  Ian
  • beaglebasher
    beaglebasher
    where about are you ninn? I know a bloke in Wollongong that loves that sort of stuff.
  • Ninnyhere
    Ninnyhere
    I am in Qld  Bundaberg.  Can freight engine case.
  • Ninnyhere
    Ninnyhere
    Can you email his contact details to me at  ininness@optusnet.com.au
    Thanks
    Redgraves Motorcycle's  Thornleigh  02 94849900 , say that Bob sent you & they will charge you twice as much     , only joking
  • Wildturkey
    Wildturkey
    ninny go see this bloke Bush Industries 170 Bargara road Bundy
    Gary Thomas ph 0419685883
  • beaglebasher
    beaglebasher
    that sounds like the go Ninny
    Keep it local
