Does Extra Front Disc Affect ABS?
  • 58bob
    58bob
    Folks, as the heading goes, does putting an extra front disc on ABS equiped SB or SG affect the calibration?
    Had a quick look on the forum but didnt see anything specific, thanks.
  • FYI
    FYI
    It may have trouble releasing the brake properly if you have double the volume with two callipers.
    The sensor itself wouldn't know the difference
  • Quack
    Quack
    Not on my Road King ???
  • 58bob
    58bob
    Thanks for the input.
    Quack, does your comment mean you fitted an extra disc to your RK and nothing was affected?
  • Quack
    Quack
    No. Stock. Non split brakes, as in both disc operate from same source.
    Would have to assume adding a second disc would be exactly the same.
